glowing exhaust
Old May 13, 2007 | 12:25 PM
witemanfromhil's Avatar
glowing exhaust
I have a 96 Fleetwood with the cast head LT1, I just put a new crank in the motor, after I got it running , I noticed the engine seemed like it didnt have enough power, I looked underneath the car thinking maybe the cat. was plugged, but on the out end of the right side cat, it was glowing red, I thought if it were plugged it would glow before the cat. I didnt have this problem before the engine rebuild.
Old May 13, 2007 | 12:48 PM
Wild1's Avatar
Make sure your valves are adjusted properly. Too tight and the headers will glow. In this case if the valves are too tight you can be over-scavenging. Also, be sure your intake isn't restricted.
In the words of Ed Iskenderian himself...
Raw (unburned) fuel is burning "late" or in the pipe (header/manifold). You may have a good equilibrium of flow going here but there is just one problem. Much of what should be inducted into the cylinder is being scavenged out the exhaust! You see, although back pressure in an exhaust system can be restrictive, the only thing that could be even worse is a reduction of it to the point where you are now, in effect pulling a vacuum. In the case of an intake restriction, very slight back pressure is preferable to avoid "over scavenging".
Search under Intake Restrictions...
http://www.iskycams.com/techtips.php#2008
Old May 14, 2007 | 09:31 PM
showstoppers-96-Z/28's Avatar
id still gut that f*cking cat, my boy had this problem in his 95 trans am, sure enough that damn cat was what was doing it
Old May 14, 2007 | 10:41 PM
F8T LT1's Avatar
It sounds like your car is running lean. I would take a look at that 1st to be safe
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Critter
Jul 7, 2015 08:33 PM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
