ENGINE IN!!! Video clips of idle-XFI 292 cam
Old May 12, 2007 | 12:44 AM
tnmotown's Avatar
I just got my motor put in a couple days ago and still trying to work out the bugs here and there. Runs awesome and still in the "break in" period. Here are a few clips of the idle. Its idles at about 950-1000 RPM's. Its the XFI 292 in my 385ci.
http://s154.photobucket.com/albums/s...rent=idle2.flv
http://s154.photobucket.com/albums/s...rent=idle3.flv
http://s154.photobucket.com/albums/s...rent=idle1.flv
Old May 12, 2007 | 05:44 AM
throb's Avatar
I'm afraid we'll have to take your word for it. To me it sounds like it's running on about three cylinders and someone is shaking a few marbles around in a coffee can in the background. Guessing you recorded it on a cell phone?
Old May 12, 2007 | 01:32 PM
tnmotown's Avatar
yeah sorry that sound quality probably does suck. i did record of a cell phone. It is much better in person. I'll see if i could get a better clip and post it
Old May 12, 2007 | 09:15 PM
MarineReconZ28's Avatar
When he finishes the break in, Ill let him take me for a ride in it and let you know.
Old May 13, 2007 | 01:45 AM
seawolf06's Avatar
It sounds like it lopes harder than mine, but it's hard to tell.
Old May 13, 2007 | 04:31 AM
throb's Avatar
Oh well, sound quality be damned, I'm sure it has some serious power!
Old May 13, 2007 | 06:54 AM
The Engineer's Avatar
I'm sure you'll be completely happy with the XFI-292 cam once your engine is broken-in and you can reallly run it. It will make some serious HP with your stroker! I also have the XFI-292 (ground on a small base lobe circle) and love the cam (11.30s).
What springs are you running with it and how much preload are you running with the 0-lash adjustment?
WD
Old May 13, 2007 | 09:14 AM
Denny McLain's Avatar
WD
Make it easy on me.......what are the XFI spec's?
Old May 13, 2007 | 05:35 PM
Check-out this Comp Cams link for LT1/4 specific cams. Basically, the XFI-292 is the biggest and badest HD roller cam Comp makes for the LT engines.
http://www.compcams.com/technical/Ca...07/168-169.pdf
WD
Old May 14, 2007 | 07:12 AM
WD
And I thank you sir.
Old May 14, 2007 | 08:14 AM
redneck01's Avatar
thats a bada$$ cam..but IMO you need more cubes, or AT LEAST heads to take full advantage of the cam. cam only is fast, but heads would help a lot more
sweet vids and i bet it sounds hella mean
Old Jun 17, 2007 | 03:09 PM
tnmotown's Avatar
I still havent been able to get another video clip of the exhaust because my tranny went out and is being rebuilt. The car does pull hard and smokes the 315 DR's i have out back! also i know i shouldnt of, but the day after the motor was in a Lambo pulled next to me and was pullin away in every gear!!
anyways MarineRecon i will give you a ride once its all together again. Where about are you in Modesto? I always go to McHenry and go the the street races at night
HectorM52
Jul 30, 2017 11:46 AM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
Cam's maro
Jan 8, 2015 05:01 AM
