buying a used cam?
Old May 10, 2007 | 12:40 PM
Spudz's Avatar
buying a used cam?
is this a bad idea? would it work like a new one? thanks
Old May 10, 2007 | 01:04 PM
BUBBA's Avatar
OK to install "used" cam as long as a qualified machinest has checked and polished the cam. Since it would probably cost you $50.00+- anyway, you will want to consider whether it is wise to buy it. JMHO. Also, if the vendor can give you proof of condition as confirmed by a machinest, it may also be an option. Otherwise....
Old May 10, 2007 | 01:33 PM
seawolf06's Avatar
I haven't had problems with used cams for our cars. The HR is much easier on the cam. As long as you can get good pics of it or see it firsthand, make sure that there are no scratches or nicks in it. Then you're good.
Old May 10, 2007 | 02:55 PM
2000GTP's Avatar
I would make sure you buy from a reputable seller. It is easy for someone to pass the cam off as one thing, only for it to turn out to be another. And as mentioned above, get pics, detailed ones at that, making sure all of the lobes are in good shape.
LeftoverChinese
Jan 14, 2024 03:03 PM
transam_388
Mar 15, 2015 11:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
