Underdrive pulley not good??
Old May 12, 2007 | 12:30 PM
95_MuLLeT_LT1's Avatar
The 95 Firehawk I just got has an underdrive pulley on it that is NOT a dampener type pulley. Its just an aluminum non damper type. The question is should I ditch this pulley for an underdrive pulley that is a dampening type?? I just dont want to have any bearing problems later because of this aluminum pulley on it. Will it kill my engine or not? LOL
Old May 12, 2007 | 12:48 PM
aboatguy's Avatar
Only if your not running the damper.
Old May 12, 2007 | 01:03 PM
Thats the problem, it actually takes the place of the damper. You unbolt the damper from the hub and put this in its place. It bolts to the damper hub. I personally dont like how that is.
Old May 12, 2007 | 01:18 PM
The Engineer's Avatar
Jeg's makes a high-quality underdrive damper for the LTs that is also SFI approved. They also have a replacment LT hub w/ key which is an upgrade over the factory type.
WD
Old May 12, 2007 | 01:39 PM
Yep, im taking this sucker off today. Ive been checking this thing out and it is actually a piggyback pulley. BUT the person that had the car before didnt bother putting the stock damper back over the underdrive. NOT GOOD. I hope it hasnt screwed anything up. Still has good oil pressure and no vibrations. For now im going to put a stock one on it.
Old May 12, 2007 | 03:21 PM
As you figured out, its a "sandwich" style pulley. You pull the stock damper off the hub, put the U/D pulley between the stock damper and the hub, and bolt it all back together.
The damage from not running the damper will be fatigue of the crankshaft, from the harmonic vibration. Its not likely much damage was done, but you never know. It isn't going to show up as lost oil pressure.
Old May 12, 2007 | 03:41 PM
Im hoping that it wasnt like that for very long. The car only has 53K on it. The 5.0 Mustang I had also had the same problem. Someone before me put the wrong Fluid damper on it. I didnt know this. and after about a year I had an oil pressure problem. I guess the bearings wore out early. Wasnt a real bad pressure problem but about 5-10 pounds less than usual. A week after that the crank broke between the #1 and #2 cyls. What a mess that made. Broke at about 6000 rpms. pretty much destroyed the AFR heads that I just put on it. Good thing I cought this or could have had the same problem.
Old May 12, 2007 | 07:42 PM
1badasZ's Avatar
long time ago when i first got my car i did the same thing lol. put a pulley on and didnt put the balancer back on...didnt know any better lol. luckily i didnt mess anything up. but over time i kept killing batteries so i took it off all together. i couldnt even drive in the rain..lights, wipers, defrost????? would die if i didnt throw it in neutral n rev on it
Old May 13, 2007 | 12:56 AM
THE_RUCKUS's Avatar
What set were you using? Most (even asp with 34 on the crank and 15 on the alt) say that full charge is maintained at 1050rpm
Old May 13, 2007 | 11:31 AM
The ASP is an integrated damper/under-drive pulley, not a sandwich type. I ran the 2-pulley ASP set (although I thought the 2-pulley set was 24%/15%)and it wouldn't keep the volt meter out of the red on a hot day with the brakes on, idling in heavy traffic, etc.
Old May 13, 2007 | 12:37 PM
THE_RUCKUS's Avatar
you are correct with the integrated damper kit, but however they also have the piggyback / sandwich styles available for around 99.99
https://www.aspracing.com/ezRetail/s...php?msg_id=254
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
94z28jbw
Sep 8, 2002 03:22 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
