lt1 in 69 camaro
lt1 in 69 camaro
i have a lt1 with a 4l60e out of a impala ss thats going into a 69 camaro. heres my question i want to delete alot of the wirring since i dont have to smog it i just needs it to run the ignintion and and the fuel injection and the alternator any help will be greatly appreciated thanks.
jonathan
jonathan
The easiest thing to do would be to leave the harness as-is, and send to computer off for a mail order tune. I thinks it only $75 to disable all of the emission stuff.
If you can find a local tuner they may be able to do it cheaper, my AIR delete, Skip shift delete, and 4.10 gear programming cost $30
Try this guy. Andrew K. Mattei [amattei@mindspring.com]. great guy and generally hangs out in the computer diagnostic section. The wiring is all BS. I subcribed to All Data and got the diagrams and locations, run two cpoies of everything and keep a log of everything you buy. You'll need it for servicing it down the road. A lot of the wiring is ABS and the such and not needed. Don't for get to program out the security key
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
