installing rail mount fuel pres gauge, need thread sealant?
Old May 9, 2007 | 01:19 PM
dbusch22's Avatar
i'm installing a fuel pressure gauge on my lt1 fuel rail where the schrader valve is. I didn't know if i needed to apply any teflon tape or special thread sealant or anything.
thanks
Old May 9, 2007 | 01:30 PM
SS RRR's Avatar
If there is a rubber gasket w/in the hose connection then no. If there isn't... I'm a big fan of teflon paste. Much easier to apply than tape.
Old May 9, 2007 | 02:17 PM
2000GTP's Avatar
Agreed, I prefer a light film of teflon paste over the tape.
Old May 9, 2007 | 02:22 PM
dbusch22's Avatar
actually there is no 'hose' or anything. i got a couple brass fittings to make a 90 degree if i need to, and then there's just the gauge.
i'm also a fan of the paste, it can get a little gooey at times though. I also didn't know if teflon junk could stand up to fuel or not.
thanks
Old May 10, 2007 | 08:28 AM
The Schrader valve is a -4AN fitting. You should not use any sealant on the conical surfaces of the fitting, and no sealant is necessary or recommended on the -AN threads. If you are screwing together some sort of external NPT thread fittings to adapt to the Schrader, teflon tape or paste sealant is used on the NPT threads.
DirtyDaveW
Dec 1, 2016 05:37 PM
MadMav
Feb 6, 2015 11:02 PM
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
97ss1826
Mar 13, 2003 11:58 AM
