I cant find the wire that goes to the temp sensor in the head
Old May 7, 2007 | 04:05 PM
93transam1234's Avatar
I just did a motor swap and cant find the wire that plugs into the temp sensor on the drivers side head.
Their is also a pigtail with 2 wires on it near the back bottom of the drivers side wheel well. But if that is the wire it wont reach the sensor.
Old May 7, 2007 | 04:15 PM
95LT1conv's Avatar
make sure you didnt mix up an ABS plug
Old May 7, 2007 | 04:28 PM
InsuranceGuy's Avatar
On my 93, the wire has a bluish connector and its in a
harness that comes from the back of the motor to'
the front along the drivers side intake. It wraps down
in front of the coil/ignition module and comes from
under #1 header tube to connect to the sensor.
93Z,383,Vortech,NOS,water/methanol
Old May 7, 2007 | 04:55 PM
bingo's Avatar
I found this pic on Shoebox's site. It should help. http://shbox.com/1/harness.htm
Old May 7, 2007 | 09:58 PM
tnx alot guys, i am sure i can find it now.
I think i mistuck it for the air pump power supply and just zip tied it out of the way.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
