Need Help Pickin a Cam
Old May 16, 2007 | 07:43 PM
blackFbird_98's Avatar
Well I just bought a 97 camaro for 2000.00 cause the Opti was out so I put the Delteq on and just got it home and threw a rod. Now Im going to put in a engine. Here is the List so far
Bored 30 over
Stroker Kit
Heads stage 1
LT4 intake from Edelbrock
Headers
And I will take the CAT's off and eventuall put the muffler on it since it is straight piped
But what cam do I get?
It is a 97 with a 6spd
Old May 16, 2007 | 08:41 PM
ryan woods's Avatar
What Is Your Hp Goal Will It Be A Daily Driver?
Old May 16, 2007 | 10:23 PM
around the 400 RWHP mark and not a daily driver. I want a lopey sound but not a really rough idle
Old May 17, 2007 | 12:39 AM
seawolf06's Avatar
GM847 seems to be popular. I like the Lunati Voodoo and Comp XFI grinds myself.
Old May 17, 2007 | 12:51 AM
95fbformula's Avatar
One question is with going with a stroker why do you only want to run a stage 1 type head set-up. That would probably be choking a lot of power out of the stroked motor
Old May 17, 2007 | 07:15 AM
rskrause's Avatar
Moderator
If you have LT1 heads, use an LT1 intake. Ports will match up better.
Rich
Old May 17, 2007 | 09:23 AM
guywithaZ's Avatar
Your HP goals seem small to warrant a stroker. LE packages can do all that for you on 355 bottom end rebuild.
Old May 17, 2007 | 01:09 PM
well for the first question I anm running short on dough so I can either leave them stock or get a L1 head
I would like to keep it with a LT1 intake but cant find them anywhere and no one in this town is good enough to do it correctly
Where can I find a LE package
As you can tell I dont know much about these LT1's so I dont know what it takes to get it to the 400+ RWHP goal
Old May 17, 2007 | 01:23 PM
guywithaZ's Avatar
http://www.eportworks.com/
Old May 19, 2007 | 01:57 PM
gas huffer's Avatar
i went with the comp cams 230/236 and got 397hp at the wheels at 6250 rpm. but i went with stage 2 cnc heads. just tryin to help ya out
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
