Am i gonna wash my engine(injector size)
Old May 15, 2007 | 07:22 AM
always faster's Avatar
Its time for me to buy some new injectors.
I want some Racetronix(Delphi).
My pcm is set for 32lbs injectors.So i though just to buy some 32 but...
Since the 37 are exactly the same price i though that would be a good choices for futur mods(head/cam etc).
If i put 37 in my car without reprogramming the pcm would i be able to drive the car without washing the engine with fuel?
Or should i stick with 32?
How many whp are these(32lbs) rated because maybe that i will be ok even with head and cam...
Old May 15, 2007 | 08:23 AM
Mike96z's Avatar
Just buy the 37, then get the computer retuned.
Old May 15, 2007 | 08:32 AM
Z-RATED94's Avatar
Before you start it up that is.
Old May 15, 2007 | 08:36 AM
SS RRR's Avatar
What's the point? Are you sure you need that much injector?
Old May 15, 2007 | 08:39 AM
Yeah i know it sound easy
Im from Canada and sending my pcm for a tune(madz28) is gonnas take to much time.
Right now i need to start the car to get it out of the garage.
But i was thinking about that(like ss rrr said) when i search in the past post on this forum.32lbs should be plenty enough for a 400whp car?
Old May 15, 2007 | 08:41 AM
Z-RATED94's Avatar
Yes
Old May 15, 2007 | 08:44 AM
Thanks i ll order some 32 and save on the pcm program
Old May 15, 2007 | 08:51 AM
km9v's Avatar
So, I guess you're getting the 14.5 K injectors since you're in Canada?
Old May 15, 2007 | 08:54 AM
Whats ???
Old May 15, 2007 | 08:55 AM
Z-RATED94's Avatar
Just don't forget to ask at what fuel pressure they are rated 32lb. Sometimes there is a difference. Do you have an adj. fuel pressure regulator?
Old May 15, 2007 | 08:57 AM
http://www.racetronix.com/621020.html
Im using the stock fpr.
Old May 15, 2007 | 08:59 AM
Z-RATED94's Avatar
Looks about right then. Good luck, and let us know how they work out for you.
Old May 15, 2007 | 09:02 AM
Do you know what KM9V is talking about...
The 14.5k since im from canada ???
Old May 15, 2007 | 09:16 AM
km9v's Avatar
Joke: 32 lbs = 14.5 kilos, Canada:metric Canadian=must explain joke. <--non ghey American wink.
Old May 15, 2007 | 09:20 AM
Man thats not nice i was doing a search on the board to find what you where talikng about and didnt came with any result.
I was about to order the injector set 5 mins ago before you made this comment so i stop my order and wait for some info
Funny guy
