94/95 harness and computer differece?
Old May 12, 2007 | 09:52 AM
madhatter's Avatar
I am doing a T56 swap in the 95. I have a computer and harness from my old 94 that had the T56. Is there any differences, or can I just swap the whole thing out and be on my way?
Sean
Old May 13, 2007 | 03:52 PM
madhatter's Avatar
Ttt
Old May 14, 2007 | 10:02 PM
madhatter's Avatar
Bump
Old May 16, 2007 | 09:03 PM
madhatter's Avatar
Bump
Old May 16, 2007 | 09:18 PM
custom95's Avatar
I'm pretty sure the computers are the same. If you wanted to, you could have your 95 computer reflashed for a manual trans. You should also be able to use the harness from the 94 that had a t 56. You may or may not have to make a few modifications to the wiring harness.
Old May 17, 2007 | 08:35 AM
GMH94Z28's Avatar
It will work. I did the same thing to my 94.
Old May 17, 2007 | 10:23 AM
BA383TA's Avatar
There is a difference. On the passenger side fenderwell the 95 has two connectors coming off of the harness and the 94 only has one. That is for the forward lamp harness.
14
Aug 11, 2015 12:03 PM
force10
Aug 10, 2015 08:30 AM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
Thirim
Jul 30, 2015 01:29 PM
