ID that sensor
Old May 13, 2007 | 10:40 AM
mvnatedog's Avatar
Cool ID that sensor
http://shbox.com/1/egr1.jpg
In that picture, it's right below the EGR valve, and above the coolant crossover pipe. It has a black rubber boot connected to a hex bolt-looking thing and a wiring connector on the other end (not connected in Shoebox's pic). What is it? On mine, the rubber boot is torn partially, is it OK if I glue it back together somehow, or should I replace the whole thing?
Old May 13, 2007 | 11:01 AM
96flame's Avatar
I think you're talking about the oil pressure sending unit. Thats the only thing I see thats between the egr and coolant pipe. Does your oil pressure gauge work? Does it leak oil?
Old May 13, 2007 | 11:08 AM
You just had to scroll down a few lines on Shoebox's photo list. I don't see a rubber boot... do you mean the plastic body of the sensor has a crack in it? If so, it needs to be replaced:
Old May 13, 2007 | 12:51 PM
mvnatedog's Avatar
Thanks, that's the one. It is the plastic housing that's cracked (not rubber, sorry), so I guess I'll see if I can pick a new one up someplace.
Old May 13, 2007 | 12:54 PM
95ttoplt1's Avatar
Get a new GM piece if you want the guage to be at all acurate. I got one from Autozone and it moves the needle but thats about all I can say for it.
Old May 15, 2007 | 09:30 PM
bowtiekid's Avatar
how hard is it to change that sensor with the engine still in?
Old May 15, 2007 | 09:47 PM
mvnatedog's Avatar
I had no problem, but I had the intake manifold off when I did it. I don't think it would be too hard with the intake on though, you might just have to move a few things.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
