Delteq hookup question
Old May 8, 2007 | 07:39 PM
dr97z's Avatar
The instructions that come with this are not very good, but anyway... I assume you do not use the plug that use to plug into the stock coil right? Then the plug for the old ignition module, does it plug into the bottom port or the top one, then vise versa for the plug that comes off the delteq that is identical to the one for the stock ICM. Thanks guys.
Old May 8, 2007 | 09:24 PM
CANTONRACER's Avatar
Top.
Old May 15, 2007 | 07:48 PM
dr97z's Avatar
Is there anybody using the Delteq setup?
Old May 16, 2007 | 06:34 AM
ZBLKHELLRZR's Avatar
If you are talking about the ICM that goes into the top right connector on the opti brain box/converter. Now if you are talking about the plug wire off the opti to the coil...no you ditch that.
Old May 16, 2007 | 04:55 PM
dr97z's Avatar
The factory ICM connector to the brainbox is what I was talking about, then apparently the connector below that comes from the delteq itself correct?
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Ari G
Dec 11, 2014 03:21 PM
ChrisFrez
Aug 12, 2002 11:50 AM
