oil pan question
Old May 14, 2007 | 03:31 PM
fireredz28's Avatar
Exclamation oil pan question
I have a 95 z28 camaro and the motor has a slight hollow knock in either #6 or #8 and im going to try new bearings in the bottom end but i was wondering if it is possible to take out the oil pan with the motor still in the car? Please help, thanks
Old May 14, 2007 | 07:31 PM
fireredz28's Avatar
nobody has ever tried to take an oil pan off before with the motor still in the car?
Old May 14, 2007 | 07:33 PM
mdacton's Avatar
search....there is 500 people asking the same thing....
Don't waste your time, its not going to work.........I didn't say it can't be done, but it will last 100 miles if you have a horse shoe up your....in your glove box
Old May 14, 2007 | 10:29 PM
fireredz28's Avatar
thats fine if there are 500 asking, nobody seems to know the answer. and im using NEW bearings so im sure they will last longer than 100 miles
Old May 14, 2007 | 10:48 PM
ak95ta's Avatar
You can pull the pan with the engine in the car. You have to unbolt both motor mounts and jack the motor up. Then you can remove the pan.
Old May 15, 2007 | 05:31 AM
mdacton's Avatar
lots of people know the answer but it gets brought up so often they don't bother to respond.....if you have bad bearing then you have a rough crank witch will eat fresh bearings very quick.....just trying to help you out
http://web.camaross.com/forums/showt...t=spun+bearing
Old May 15, 2007 | 06:33 AM
rskrause's Avatar
Moderator
As "mdacton" said, this form of ghetto repair is pretty much doomed to fail. Either method stated for dropping the pan w/o removing the motor will work. Dropping the crossmember give better access but takes longer and (obviously) requires a lift. Jacking up the motor can be done on jackstands.
Rich
Old May 15, 2007 | 08:22 AM
Mike96z's Avatar
Actually you can take the pan off, no problem, the only thing youd have to do is.................pull the transmission, drivershaft, exhaust, K-member then the crank + ud need help, and have a cherry picker to hold the engine up which will be in your way the whole time. So you might as well pull the whole engine.
UNLESS! You are only changing one of the bearings on the crank, but I dotn think thats the prob, it may just be ping. Well if your not gonna pull the crank but only replacing the bearings one side it may be possible, but dont let anyone you cant pull the pan on the car while the motors in it, Ive dont it a million times and just did it again last night but with a 7qt race pan, now thats a bitch.
Old May 15, 2007 | 10:10 AM
fireredz28's Avatar
thanks for all of the help guys
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
