How many ground point on the engine?
Im still searching for my problem after my new motor install(cranking but no start) i ve check my ground to see if they are good or if there is a missing one.
How many grounds point does the engine have:
-Strap from the driver head stud to the body
-2 wire from that are in the same looms has the icm/coil/maf to the driver head stud
-1 wire from the starter loom that goes to the pass side of the block
Am i missing one?
Am i missing one?
What about the main battery cable ground to the block?
sorry, but....do you have gas in the tank?
did you recheck your plug wires?
or maybe the position of the opti when you re-attached it. you know, the circle that spins on the back.
I dont know how many time i ve been ask for ths question...My tank is full of gas.
My plug wire are good and i even try 2 set.
The pin drive opti is well set but i ve order a new one to see if this is the problem.
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
I didn't think it would be cranking without that one. You probably have an issue with something else.
