oil pump/pick up tube?
Ok, I took the oil pan off of my motor (94 vette lt1) and I have a 94/95 z28 pan I am going to put back on it as it's in a lot better shape and the drain plug is in a different location. After taking off the vette pan, I noticed the hole where the pick up tube fits in is different and the camaro pan won't fit. I went to a dealer to get an f-body pick up tube and was going to replace the pump as well while it's apart. I was told that there is two different pumps and two different pick up tubes available for 94 z camaros. They are different tube sizes and I'm figuring that one might be like the vette one that's on the motor and the other may be the one that would work with the camaro pan I intend on using. The motor only has 44k on it, should I replace the pump, or leave it and just try to get the pick up tube that will fit the pan? Also, there was an o-ring and a gasket between the piece that the oil filter screws onto and the block (also the same piece where the oil cooler would thread into). The o-ring looks good, but the gasket came apart when taking it off to get the pan off. The dealer shows one part number and they weren't sure if it included the o-ring and gasket or just the o-ring. Does any one know? Input needed.
thanks!
thanks!
Jul 4, 2005 05:00 PM
