Le3 Questions
Old May 15, 2007 | 08:49 PM
95fbformula's Avatar
Le3 Questions
I am currently building a 355 and I am expecting to pick up my block very soon and need to decide on H/C choices. My question is the Le3 set-up to big for a street driven 355 I am looking to turn the motor to about 6800rpm and have it dyno tuned.
My build consist of
Zero Decked block
Mahle forged -5cc flattop pistons for 6" rods
Scat forged 6" I-beams
stock polished crank
Internal balanced
1.6RRS
EWP
Hooker LTs no cat or any emissions
A4 with 3600 stall and 3.73 gears in the back.
36# injectors
58mm TB
Intake work to match heads.
Old May 15, 2007 | 09:01 PM
reamo04's Avatar
so....what are your questions?
Old May 15, 2007 | 10:49 PM
Javier97Z28's Avatar
Moderator
No, it's not too big for a street driven car.
Go with 4.10 / 4.11's with an LE3... 3.73 is not enough gear (IMO).
Old May 15, 2007 | 11:34 PM
Thx that answers that i guess I will have to go with a LE2/Le3 cam kind of set-up
Old May 16, 2007 | 09:28 AM
OldSStroker's Avatar
Did you mean LE2 cam, LE3 heads? It's the cam that determines how much gear you need. You might ask Lloyd for a H/C combination that fits your setup and desires. There are quite a few LE cams for specific applications.
Good luck.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
Red_94Formula
Jan 22, 2015 12:17 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
