Header EGR hookup...might not be perfect
Old May 9, 2007 | 11:16 PM
eagleknight97's Avatar
How big of a problem would it be if the EGR tube that hooks up to the header isnt perfectly on there. Say for example the tube wouldnt go all the way into the hole on the MAC header and I just kept cranking on the bolt and the tube MAY have slightly deformed
Old May 10, 2007 | 08:10 AM
You do NOT want a leak in the system at that point. It will dilute the exhaust and screw up the O2 sensor readings on the passenger bank. A severe leak could result in a problem with the exhaust valve on #8.
You are talking about the EGR tube, and not the AIR tube(s) - correct?
Old May 10, 2007 | 11:00 AM
Yeah, EGR tube, coming off the back of the manifold.
Old May 10, 2007 | 11:08 AM
Dave1980's Avatar
why is the tube binding? Is the the hole too small or not shaped right to receive the EGR tube?
Old May 11, 2007 | 09:36 AM
ashakeandfrys's Avatar
mine was the same way on my pacesetter mids.. the egr has a "collar" or whatever you want to call it that I had to remove from it so it would be flush. Prior to that mine deformed and I did the same thing you did.. but i took it off and put a small socket in it and shaped it that way.
Old May 11, 2007 | 10:12 AM
Well, I crimped the part that goes into the header and I THINK its in there now, but am not completely sure. If I have a problem with it, Ill try taking it off at the manifold and blocking it there and on the header.
Old May 11, 2007 | 01:02 PM
kertong's Avatar
When I had MAc mid length headers, my EGR tube would not fit flush to the flange. Turns out there was a bead weld inside the flange that prevented the EGR from sitting flush.
I had to use a dremel to cut about 1cm off the brass tube of the egr. I then sealed it with a good gasket and some copper RTV, and torqued it good.
MACs got rave reviews here, but I don't see the big deal about them. On top of the bead weld preventing the egr sitting flush, I had a pinhole leak from shoddy welding at the driver's side collector. Be careful!
Good luck!
timmy39120
May 8, 2015 11:41 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
k1996z28
Jan 21, 2015 07:22 AM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 18, 2014 12:57 PM
