Is this bad to do?
Old May 14, 2007 | 09:10 PM
Mortify's Avatar
Is this bad to do?
On Sunday I was inspecting my car because it was running pretty bad, shuttering and bogging a bit, poping in my LTs and running really rich... I noticed that 1 of my plug wires was burnt, as I was trying to move it away from the header it broke apart at the burn... I looked around at local shops for wires but it seems they need to be ordered in.
Would it be ok to run my car on 7 cylinders if I disconnect the injector and remove the wire completely until I get new wires?
Old May 14, 2007 | 09:11 PM
93v8clone's Avatar
um not really good at all but if ya had to as long as ya unplug the injector it shouldnt wash down
Old May 14, 2007 | 09:14 PM
JP95ZM6's Avatar
Shouldn't hurt anything. There was even a v8 diesel Olds that always ran on 7 cyls, the 8th was used for the fuel pump, IIRC. Of course it was NOT a one of Olds' better designs....
Old May 14, 2007 | 09:20 PM
ChevyTuffD.A.'s Avatar
Why dont you just go to the auto parts store and buy a cheap set of wires and then just pick the one thats fits the best and throw it on there until you can get a set ordered. There is also the option of just making your own plug wire. Why chance it with running it on 7 cylinders? You get what I mean?
Old May 15, 2007 | 09:29 AM
2000GTP's Avatar
Thats what I would do.
Old May 15, 2007 | 12:20 PM
oneclean97z's Avatar
amen
Old May 15, 2007 | 05:04 PM
Metlhed54's Avatar
yeah im gonna put a vote toward finding at least a cheap replacement for the time being. what costs more, temp spark plug wires or the engine problems that could result bc ur driving on 7 cylinders? i wouldn't risk it.
Old May 15, 2007 | 05:10 PM
shock6906's Avatar
Let me guess...3rd cylinder back on the driver's side? Same one I just burnt through. Get OTVC wires and it should solve your problem. I ordered a set and will be installing them this weekend.
Old May 15, 2007 | 06:58 PM
The Engineer's Avatar
I think I would rig a temporary plug wire before shutting-down the cylinder.
WD
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
