Air pump part number
Old May 14, 2007 | 09:48 AM
multicar's Avatar
Well I got the dreaded air pump code along with the blown 20amp pump fuse, so, I removed it and peeled it open. Out comes about 1/4 cup of water, a saturated foam noise dampener and some corrosion. After cleaning it up, I hooked it back up, while apart, and it ran fine without the fan blade attached. I know there is a recall on this, so don't go there. In case I need to replace it, does anyone have the part number or cost on it. The last time I took my car to the dealer, they went on a 50mile joyride and said it was for diagnostic purposes..yeah right.
TIA,
Doug
Old May 14, 2007 | 10:37 AM
multicar's Avatar
NM, got it....12554580, ~$131.00
Old May 14, 2007 | 10:59 AM
tireburnin's Avatar
Don't spend that much on one. Go search the parts for sale area.
I even have one I could sell you for cheap (make me an offer). But don't throw money away on a part that many board members have sitting in a shed.
Old May 14, 2007 | 11:32 AM
shock6906's Avatar
Damn, I just threw mine away a couple weeks ago. I'd have sold it to you for much less than that.
Old May 24, 2007 | 10:44 AM
multicar's Avatar
Update....
I cleaned out the water and a little sludge and it works fine. The motor is a sealed unit. I also replaced the rubber seal at the solenoid for good measure with a neoprene washer from the plumming dept at the local h/w store. I even drilled a small 1/32" hole for future water relief right above the lower mounting nut.
Some notes:
- the large plastic cover snaps straight on, w/4 tab catches and is removed first
- the smaller cast aluminum cover spins off.
- the fan blade nut is reverse threaded.
- after cleaning the center section, I clear-coated both sides.
- used black RTV to seal both covers.
- let it sit for 24hrs after sealing it, before installing it
It wasn't that bad of a fix...just takes a little time.
regards,
Doug
HectorM52
Jul 30, 2017 11:46 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
CobraEatr
Jul 22, 2002 09:49 AM
