Camaro newb Needs help! Coil Probs i think
Old May 10, 2007 | 07:04 AM
Jaronk56's Avatar
So after car dieing out and not starting up at emmisions how ironic......
anyways got a fuel gauge it reads 43 psi then i checked spark... no spark so yea i found this from shoeboxs
To test the coil, went to msd site to find acutal ohms
Primary Resistance: 0.45 ohms
Secondary Resistance: 5.5K ohms
i tested all four they're all at about 5.30 on my ohm meter
the coils good??? I searched still im still lost... if you guys think the coils still good what should i do next... its got the msd ignition box too...
thanks guys I just need a lil help before i waste all my money and my time!!! !
Jaron
Old May 10, 2007 | 07:11 AM
Your test means there are no opens in your coil windings. Bypass your ignition box for testing and check that there are firing signals getting to the ICM.
BTW, PLEASE post basic info on your car. (the sig is a good place for that)
Old May 10, 2007 | 07:42 AM
Jaronk56's Avatar
I feel like an idiot but i seriously need help whats the easy way to bypass this??? someone breifly explain it! Please!
im a syclone guy im new to the optispark and all this BS!
thanks Jaron
Old May 10, 2007 | 08:09 AM
When you use an MSD harness to install an MSD box, you merely unplug the harness and plug everything back to stock. If it is hard wired, then it's not really going to be easily done.
Old May 10, 2007 | 10:10 PM
Jaronk56's Avatar
Thanks it was the msd 6200 ignition that went bad... does this happens alot? i bought a new one and it works great.
Old May 11, 2007 | 09:11 AM
Rodrigues's Avatar
I've got a few bad ones on the shelf.
Lt1son
Dec 22, 2014 10:58 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
kandied91z
Aug 6, 2002 01:18 AM
86IrocCamaro
Jul 22, 2002 09:44 AM
86IrocCamaro
Jul 22, 2002 05:57 AM
