Cam Swap??
Cam Swap??
I'm doing a cam swap and I need a new timing chain. I want the lt4 chain, do I need to get the whole set with the cam and crank sproket, or can I just get the chain itself? That and what would be the best roller rockers for a cc306?
Timing chain depends on what opti and timing cover you got. For RR's you may as well do 1.6 while your in there replacing valvesprings and stuff anyway. Plus their good for a few horses! I'd personally do non self-aligning RR's with hardened pushrods and GM guideplates for a sturdier valvetrain since you have to rev high with that cam.
