ECM Part Number.
Old Nov 24, 2003 | 12:18 AM
1FstFormulaV8's Avatar
ECM Part Number.
I need the part number for the ECM on a 1993 Pontiac Formula LT1 OBD1.
Thanks Guys.
Old Nov 24, 2003 | 12:38 AM
madwolf's Avatar
The part number is:
16159278
You will also need a PROM chip with the PCM. It is removable and you could just use the one in your current PCM. (if the PCM went bad and you want to replace it)
Otherwise, you will need to order it separately.
Old Nov 24, 2003 | 01:06 AM
madwolf's Avatar
Yes, I was talking about the ECM. The part number is right.
ECM = Engine Control Module
PCM = Powertrain Control Module
Even if the used term for the 93 unit is ECM, calling it a PCM couldn't be wrong either, since it still controls some transmission functions.
Old Nov 24, 2003 | 01:07 AM
I think the service fellow said I needed a new ECM. It wasn't kicking my fan on. I know I can change it myself...couple of connectors need to be unhooked and plugged back in.
Old Nov 24, 2003 | 01:37 AM
madwolf's Avatar
Yep, it's easy to change. Just make sure you take out the PROM unit before you trade the old one in as a core. You will need the PROM for your new ECM.
Old Nov 24, 2003 | 08:14 AM
The service shop said..."the 02 sensor is not responding" I don't know if this is an ECM problem or the sensor just failed. Any idea?
Old Nov 24, 2003 | 03:18 PM
Is the Promm soldered to the board? I'm new in the LT1 engine. Does anyone had a picture of the Promm in the ECM/PCM?
novaiiman
May 15, 2016 11:36 AM
warmeck
Jan 20, 2015 09:20 PM
4586
Dec 31, 2014 02:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
