How to stop header leak on slip in primary???
Old Nov 23, 2003 | 04:16 PM
speed76demon's Avatar
Angry How to stop header leak on slip in primary???
Alright i've had the headers in for 5months no leaks until the other day I thought I kinda notice a diff noise from under the hood so I got out popped it and to my suprise my #1 primary is leaking. The one that slips in. I was just wondering what I can do to it to get it to stop leaking. Any ideas/suggestions will be greatly appreciated.
Old Nov 23, 2003 | 04:49 PM
96BlackTA's Avatar
I bought a 1 3/4" T-bolt clamp from summit racing and it held up pretty well.
Old Nov 23, 2003 | 05:13 PM
ChevyIron's Avatar
Same here got the t clamp and no leaky.
Old Nov 23, 2003 | 05:18 PM
Javier97Z28's Avatar
Moderator
I used RTV, hasn't leaked in almost 2 years.
Old Nov 23, 2003 | 06:31 PM
RTV?? Are you talking about gasket sealer?? Also would it be high heat b/c I would think it would have to be
Old Nov 24, 2003 | 09:00 AM
no other help??
Old Nov 24, 2003 | 09:38 AM
93transam1234's Avatar
i tried
I have tried almost everything from hight temp RTV - Furnace cement- pipe expander none have worked yet i am going to get the tclamp today..i can let you know how it works.
The reason my kept comming lose is because i will botton out the car sometimes and it will hit the collector or y-pipe and break what ever seal i had made in the primary by moving it around.
If the t clamp doesnt work i am going to take out the header and get it welded...
Old Nov 24, 2003 | 01:29 PM
I think that is most likely why mine is leaking b/c of bottoming out either that or b/c it is getting so cold maybe the pipe shrunk I dont know but I'll prolly be ordering the t-clamp sometime this weekend
Old Nov 24, 2003 | 02:25 PM
Moderator
Yep, used hitemp RTV.. my car never bottoms out tho, sometimes hits the Y, but has never affected the headers.. stock ride height.
Old Nov 24, 2003 | 03:46 PM
QCKZ28's Avatar
i never could get hirh temp rtv to fix it permanently, i will try the clamp......anybody got a p/n?
jesse
Old Nov 24, 2003 | 07:52 PM
97WRAITH's Avatar
summit racing part number sup-094-1750. I am using this t-bolt clamp and works great.good luck!
Rob.
Old Nov 24, 2003 | 08:28 PM
DrivinSidewayz's Avatar
i had a leak in my header, a big *** rock appeared from a car infront of me, i couldnt avoid it, dented my cross member and header, no more leak... lol, so go run over some boulders!!
Old Nov 25, 2003 | 12:47 AM
ZyberMunster's Avatar
Sorry for the "dumb" question but how does this T-clamp look?? Anyone has a pic, drawing or site where I can see it??
I have a U-clamp on my slip-on primary it works so, so.
Laterzzz...
Old Nov 25, 2003 | 05:28 PM
97WS6SCharged's Avatar
Buy some one piece headers and keep everything tight.
Old Nov 25, 2003 | 05:47 PM
doodad's Avatar
bump for reference cuz I need that part too.
Keenan
Jan 19, 2023 12:24 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
