I need help with 1le intake elbow!
Old Nov 22, 2003 | 09:11 AM
cridom's Avatar
I ordered an elbow from ls1speed and i have a 94 but it came with the little hole i guess for vented opti is it possible to close it with something?
thanks
Old Nov 22, 2003 | 09:15 AM
jasons93z's Avatar
the hole is for the IAC.
Old Nov 22, 2003 | 09:22 AM
cridom's Avatar
the hole it has is very little and it also comes with the connector thing so it has like 2 hole 1 is in the side and up is on the top
Old Nov 22, 2003 | 12:00 PM
cridom's Avatar
ttt
Old Nov 22, 2003 | 12:36 PM
jasons93z's Avatar
IT IS THE IAC SENSOR. Am i speaking spanish and dont know it
Old Nov 22, 2003 | 12:37 PM
AxeGrinder30thZ's Avatar
I was wondering the same thing. Why is that so hard to figure out? It's the same hole that's on the stock elbow...so?
Old Nov 22, 2003 | 12:38 PM
95BlackTA's Avatar
When you took off your old Elbow you must have unplugged the IAT(not IAC, IAC is in the Throttle body) sensor. You gotta plug it back in.
http://shbox.com/1/iat.jpg
See
Old Nov 22, 2003 | 12:42 PM
See
LOL. Knew it had to be one of the IA's.
Old Nov 22, 2003 | 12:43 PM
jasons93z's Avatar
See
Thats exactly what i told him I dont think that he understands that you have to plug the IAC sensor back in
Old Nov 22, 2003 | 12:55 PM
LWillmann's Avatar
Maybe I'm an idiot and am wrong, but my understanding about the elbows is:
There is a spot for the IAT - Intake Air Temperature (not IAC) sensor on the outside (read: long side) of the bend in the elbow.
On the elbows for cars with the vented opti, there is also a small connector (hole like for a small vacuum tube) for the vented opti.
The IAC is the Idle Air Control motor and it physically mounts to the bottom of the front of the throttle body, and not in the elbow.
So if your elbow has the opening for the vented opti, then I'd hit Autozone or some other similar parts store looking for a vacuum tube in-line connector and a vacuum cap. Put one end of the in-line connector into the small hold on the elbow and the cap on the other end of it and you should be fine.
Old Nov 22, 2003 | 01:02 PM
Mtrhds94Z's Avatar
The 'late' 1LE elbow[which is the cheaper of the 2] has the hole for the opti vent on top..
I just stuck a small screw in there.. works fine...
Old Nov 22, 2003 | 02:11 PM
cridom's Avatar
ok someone at least got it!!
i was saying that i know where to plug the iac but there is a small hole for vented optis only and my car is a 94 so its non vented so the hole is extra so im putting a screw there thanks
Old Nov 22, 2003 | 02:16 PM
jasons93z's Avatar
I would call up ls1speed then because they are sending out the wrong elbows.
Old Nov 22, 2003 | 02:18 PM
94zLT1's Avatar
Red face
ok retards...the one on the side is for the IAT (air temp to PCM) and the one on the top is for 95 and up vented opti..and more brain busters......
Old Nov 22, 2003 | 02:20 PM
FacelessZ's Avatar
Thought you guys would have had this under control with the first post reply...
