Where can I get a Block off plate for an LT1
Old Nov 21, 2003 | 01:38 PM
94B&RZ-28's Avatar
For the EGR, I don't want to make it, just easier to buy it
Old Nov 21, 2003 | 01:41 PM
FacelessZ's Avatar
http://www.sjmmanufacturing.homestead.com
ollie-99's Avatar
talk to steve
z28freak@hotmail.com
http://www.mycamaroz28.homestead.com/
Old Nov 21, 2003 | 10:19 PM
94B&RZ-28's Avatar
thanks guys!
Old Nov 21, 2003 | 11:42 PM
Josh'95Z28conv's Avatar
I just cut and crimped the old tube like 3" from where it bolts to the manifold. Then I welded it
Old Nov 22, 2003 | 10:31 AM
94B&RZ-28's Avatar
I did that in my 94 3 years ago too. INstead of spending $24, I may just do it again
Old Nov 22, 2003 | 10:34 AM
Shockwave's Avatar
Lounge Moderator
Moving to LT1 Tech.
Old Nov 22, 2003 | 04:25 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
shockwave..... VH rules
Old Nov 22, 2003 | 08:48 PM
LWillmann's Avatar
I bought the EGR valve blockoff plate (for the LT4) from Jason Cromer, and plan to crimp the EGR tube and use a coke can to cover the tube plate in the back.
Old Nov 23, 2003 | 03:33 AM
revtime's Avatar
I used the EGR block off plate and then I took the metal hose out of the plate and got some high temp gasket material and cut out a solid gasket to go back in there and seal up that hole.
Old Nov 23, 2003 | 08:01 AM
oldBones's Avatar
Used a tin can that I cut out to a flat piece with tin snippers and drilled holls in the can for the studs and used the gasket that came in the intake manifold kit. and there was a block off plate, whoo!!!
Old Jan 6, 2004 | 11:18 AM
Tires_Smokin's Avatar
Ok real quick! , I'm doing a header install and when I was removing stock passenger manifold, the egr tube bolt was solid at the 02/flnage toward the y-pipe...stuck after several hours of attempts. I just cut the stupid egr pipe so I can get the manifold off but I want to remain emmissions legal. I was wondering if there is a way to pass the codes of EGR flow. I actually want to do the plate so I dont have to hasle with that annoying hose. But at time of smog, I'll throw up a code right? And SES light? Lemee know if theres a way to ditch the SES and code on this if thats the case..
thanks..
Old Jan 6, 2004 | 11:38 AM
tryintogofast's Avatar
Umm...yeah that will throw a code. Hehe you need that hose there for the egr to function properly. If you want to get rid of the code you're going to have to get it programed out. good luck
D1SC383LT4
Jan 26, 2015 01:41 PM
alphaauto
Jan 23, 2015 07:42 AM
jocamino
Dec 29, 2014 10:15 PM
Catmaigne
Dec 25, 2014 12:16 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
