Adjusting Crane Gold's..
Old Nov 21, 2003 | 03:26 PM
flyinZ's Avatar
I was wondering if anybody had a "tech guide" or knew the proper way to adjust Crane Gold 1.6 roller rockers..SA...I wasn't sure how to..I've had a few people tell me, but what about bleed down?? Motor running or off?? Any help would be great..Thanks!
Old Nov 21, 2003 | 03:38 PM
joeSS97's Avatar
Do a search for Shoebox and go to his tech page.I know he has a guide for it.
Old Nov 21, 2003 | 03:42 PM
Red_94Formula's Avatar
there is nothing about bleeding involved with rockers. dont get confused with that. let the motor idle and have the rockers with the nut on loosly. tighten the nuts by hand until there is zero lash. just turn the nut until it stops. as you do this you will notice that clacking going away. turn motor off and turn each nut one half turn and put the locks in them. use a wrench on the nut when tightening the lock nuts.
Old Nov 21, 2003 | 04:08 PM
There is no difference on adjusting for different brands of rockers that I know of. The only thing I know of close to that is if you use Comp R lifters that require only about 1/4 turn of preload.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
