anybody,everbody need your $0.02
i have a 95 z with all the mods in my sig...im sending my pcm to ion monday morning 11/24...im also installing some 1.6mag rr.
would you recommend a tune on a "stock"car???
i was just gonna have the the top speed limiter removed, rev limiter raised, gears/speedo recalibrated, and lower fan turn ons.
i dont know what to do...need thoughts now so i know what to do tommorrow?
thanks again,
steve
thanks again,
steve
Originally posted by CamaroBoy96Z28
Theres nothing to really "tune" on a stock car so I'd have to vote no. Everything you listed is about all you can do AFAIK.
YES you CAN benefit from a tune on a STOCK engine... Our car's run at like a fat 10.8:1 in the upper PE Tables causing the car to run HELLA RICH on a stock tune...
TUNING =
I think most likely the "tune on a stock car won't pick up much" myth is probably from the fact that handheld tuners like the Hypertech suck donkeys.
EDIT: By the way, I agree there is not much to be had with timing tweaks, but plenty in the PE Tables (A/F Ratio).
