Anyones A4 ever leaked from around the SPEEDO sensor?
Old Nov 23, 2003 | 07:11 PM
BlackLT1_TX's Avatar
I was under my car doing Shoebox's tranny cable adjustment since my shift never wants to come out of park. Well, I did it just like it said and it still does the same thing
But anyways, I noticed that there is a leak coming from speedo sensor. It is like a circle with a plug going into it, and from the bottom of the circle it must be slowly leaking.
So, where can I find that seal, and should I just pull it out and put the new seal in? How much fluid will I loose?
PS- I am not a newbie with cars, I have pulled alot of transmissions, I just havent ever been into a 4L60E since I have been a mustang guy working at a ford racing shop.
Thanks alot,
James
Old Nov 23, 2003 | 07:15 PM
NewbieWar's Avatar
yea mines leakin right now
just donno what i wanna do about it...
none of the local shops have a Speedometer sensor o-ring, so i dont wanna take it off to show them, then i wouldnt have a ride
Old Nov 23, 2003 | 07:19 PM
Man, I was hoping someone responded with an answer!
Well, I guess the dealer would probably have to have it, it probably is the same on all 700r4/4l60/4l80 etc. Maybe not, but I would think so.
Old Nov 23, 2003 | 11:21 PM
12SCNDZ's Avatar
It's a very common o-ring. If your local shop tells you they don't have one, they're full of sh#t. I've got a box full of them at the shop. The 700/early 4L60Es used the same speedo o-ring as every PBO TH350 produced.
Frank
All-Trans Transmissions
Old Nov 23, 2003 | 11:49 PM
NewbieWar's Avatar
they said they had universal ones, if i brought the right size in, they could match it...
maybe i'll try napa
Old Nov 24, 2003 | 07:56 AM
VSS
You might need to catch a little fluid that comes out when you remove the sensor.
Old Jan 25, 2004 | 04:01 PM
SCNGENNFTHGEN's Avatar
Hey Shoebox awsome site it has helped me many times, just wanted to say thanks. Anyway mine is leaking too. I never noticed when it was in the old Z. Now that I have the swap( 94LT1/4L60e from old Z in my truck) done, however I've noticed the VSS is leaking. Well its alsmost done, when are they ever done anyway! Mine is also a slow leak, as there is bearly a spot from it. I asked a buddy who used to run a trans shop, he told me also to bring it in and he could match it up. I was going to drive the rear up on ramps in hopes of not losing much fluid. I would really rather get the o-ring first so its an in and out deal, I don't want to leave it open, while I go to get it. Does anyone on here know what the GM part # is?
Old Jan 25, 2004 | 04:15 PM
Question VSS
Oh, and I never had one out. I there any springs gonna shoot out at me or anything like that? Thanks!
Old Jan 25, 2004 | 04:39 PM
dnz28's Avatar
nope, but tranny fluid will come out so be prepared. just un bolt rplace the o-ring and bam your fixed. dont for get to put in tranny fluid.
Old Jan 25, 2004 | 05:15 PM
NewbieWar's Avatar
whats the damn size on that thing, i wanna replace it, but everywhere i go they say they donno what size it will be and that i have to take it off... i even went to the transmission place down the street they said the same thing...
does anyone know the size on it?
I just found the part # on your site, thanks again Shoebox. I didn't even see that section before.
Old Jan 26, 2004 | 10:31 PM
It was right on the VSS pic link I posted before, too.
Old Jan 26, 2004 | 10:44 PM
NewbieWar's Avatar
do you know what the demensions are?
im trying to buy it locally and nobody has a clue what size it is.. not even the transmission shop
and i dont really wanna take it off till im ready to replace it
Old Jan 26, 2004 | 10:48 PM
Sorry, I don't have that info. Why do all the searching? Just go to a GM dealer with the p/n. It's only $1.83 even at list price.
Old Jan 27, 2004 | 06:23 AM
12SCNDZ's Avatar
Apparantly the people who work at your local transmission shop are morons. Yes, they're are 2 different VSS sensors they used in 4L60E's...Early and late. Early units are the same o-ring as a PBO TH350 and a 700R4. Later units used a smaller o-ring which was the same as the old Chevrolet TH350.
Yours is an early unit...Just go get an o-ring for a 700R4.
Frank
mikey4play
Mar 15, 2015 11:45 AM
Cam's maro
Jan 8, 2015 05:01 AM
birdblack
Dec 30, 2014 06:59 PM
Cam's maro
Dec 29, 2014 08:44 AM
nikko
Dec 2, 2014 03:43 PM
