Question about Vacuum.
Old Nov 22, 2003 | 02:28 PM
LT1ponykilla's Avatar
I still think there is something wrong since my cam was installed. I have recently changed the opti, plugs, wires, and everything else. I still dont think Im getting any power from the cam. Next week Im planning on pulling the front of the motor apart and checking my timing chain. Before I do that I was gonna try to get some readings with a vacuum gauge. I know if its low that means I could have a vacuum leak somewhere or the timing chain could be off a tooth and not lined up properly. If the vacuum looks ok on the gauge does that automatically mean that the timing chain and dots are lined up properly?
Old Nov 22, 2003 | 05:58 PM
TTT
Old Nov 22, 2003 | 07:03 PM
Well, I got the car on a vacuum gauge. It was reading anywhere between 8-11''s of vacuum. It was mainly staying around 9.5-10.5 but then it would drop down to 7.5 and go back up to 11. It was never a real steady reading. What do you guys make of this?
Old Nov 22, 2003 | 08:22 PM
I would be most helpful if you posted what rpm and what you were doing when you got those readings.
That could be a little low for idle, depending on the LSA of your cam and spark timing/rpm.
Old Nov 22, 2003 | 08:51 PM
The readings were taken at idle. I have the xe 224/230 cam on a 112 LSA. Like I said, the readings werent stable at all.
Old Nov 22, 2003 | 09:02 PM
But what is the idle rpm set at? If it is way low, you will get poor vacuum. Adding timing can help, but nothing will make up for it if it is off a tooth on the cam gear.
Old Nov 22, 2003 | 09:29 PM
OBE1 95Z28's Avatar
If you idle isn't stable, that could explain your vacuum jumping around. I run a CC 218/230 114LS cam & 1.6 RRs with my idle set at 900 rpm (M6) and I get 17" of vacuum.
Old Nov 22, 2003 | 10:09 PM
My idle is set around 900rmps. Is the vacuum kinda low for my cam and do you think it could be the timing chain being off?
Old Nov 22, 2003 | 10:34 PM
OBE1 95Z28's Avatar
You cam's bigger than mine but I wouldn't expect your vacuum to be that low. I would suggest that you check for other vacuum leaks before you pull the timing chain cover off. Pull all the vacuum lines off the intake and plug the intake ports, then see if your vacuum improves.
Old Nov 22, 2003 | 10:36 PM
atljar's Avatar
I would say that it is low enough to cause enough concern to dive into the motor. You could try spraying some starting fluid around the base of the intake too. If the car revs up you have an intake man leak. If it doesnt rev, still doesnt rule out intake leak completely, but its something to check.
My cam pulls about that much vacuum at 900 rpms and its quite a bit larger. Good luck.
Old Nov 22, 2003 | 11:53 PM
Where should my vacuum be at with my cam and at idle?
Old Nov 23, 2003 | 01:13 AM
atljar's Avatar
All engines will be a little different. Find someone with that exact cam and ask them, but i would guess 14-15 inches.
Old Nov 23, 2003 | 11:15 AM
So its possible then that my timing chain wasnt setup dot to dot then or I have a vacuum leak somewhere?
As of now my car doesnt feel like its any faster from my cam. Good thing I checked the vacuum to make sure it was low. Thanks guys.
Old Nov 23, 2003 | 09:44 PM
onebadponcho's Avatar
Mine pulls around 15.5" vacuum at the stock 800rpm idle. It used to pull about 21" before the cam; at least my brakes still work.
Old Nov 23, 2003 | 09:47 PM
So mine is a little low then. I should be around 15 or more. With it being that much off, how much could my timing chain be off if that is the problem?
