weird smell after 130
Old Nov 22, 2003 | 12:30 AM
Seal's Avatar
I went WOT on the highway once, and after i passed 3rd gear, and kept pulling in 4th gear, at about 130-140 there was a burning smell... cant really explain it, but didnt smell good :P
what can that be from? i had ****ty tires, can that be why? it never does this unless i'm going pretty farking fast...
(yeah i know going that fast isnt smart, but i was curious whats the fastest i can go, and i let go after i smelt that thing)
Old Nov 22, 2003 | 12:32 AM
IrocManiac's Avatar
You could have a brake pad thats hung up just a little...
Old Nov 22, 2003 | 01:01 AM
Seal's Avatar
very possible....
thx
Old Nov 22, 2003 | 01:54 AM
97WS6SCharged's Avatar
Weak clutch(es) maybe?
Old Nov 22, 2003 | 07:34 AM
sandmanljs's Avatar
What kind of tres do you have, and more importantly what speed rating are they??
Brakes sound like a good possibility.
Old Nov 22, 2003 | 08:57 AM
ElkyRacer's Avatar
Did it smell like burning plastic? Coming from INSIDE the car? With that long of a period of WOT, I bet the heater core box in the engine bay started to get a bit warm. I know mine does after just a short drive on the highway (3200rpm at 60), but thats with longtubes that come very close to that box.
Kyle
Old Nov 22, 2003 | 09:05 AM
Red_94Formula's Avatar
Sounds like an automatic to me. check the fluid and make sure it is still red.
Old Nov 22, 2003 | 11:34 AM
IrocManiac's Avatar
Thats another very distinct possibility if the fluid is not red or smells burnt you could have some other problems...but generally a tranny will give you a sign that its not working properly...a little slow between shifts and themotor will rev up slightly...but still worth checking into.
Old Nov 22, 2003 | 01:16 PM
Seal's Avatar
I'll check the fluid...
my tranny was rebuilt i think... cuz at 96K miles, its shifting better than my roomates's 30K mile 98 z
i chirp tires all the time
there was also a speker wire that the prev person put on that i noticed melted into the back of engine (which i need to take out :P) but that wouldnt make it smell only if i'm going real fast...
the tires i had were T rated, and when i took it to the tire place they said i could have gotten a blow out if i went another day with them (inside was ripped he said)
now i have W rated tires
I'll go check the fluid now
Old Nov 22, 2003 | 01:17 PM
Seal's Avatar
oh yeah, and what is it supposed to smell like
Old Nov 24, 2003 | 07:46 AM
Camaro94Lover's Avatar
If it was more like a rotten eggs smell it may be coming from the catalytic converter.
Old Nov 24, 2003 | 04:00 PM
BUBBA's Avatar
130? Better check your shorts.
Old Nov 25, 2003 | 01:19 PM
tufZ's Avatar
bad smell
My oil temp gauge usually reads 220F but when I pegged my speedo (155MPH +), it registered 260F+ and had that burning smell. It's an A4, but the tranny held up for another 50thous miles, so I doubt any damage done to the tranny. I guess the higher engine temps just burned the gaskets like valve cover and other simple stuff.
Old Nov 25, 2003 | 01:20 PM
FacelessZ's Avatar
haha you could be smelling your valvetrain burning up...
Old Nov 25, 2003 | 01:42 PM
Seal's Avatar
that would be RPM based though
and it better not be my valvetrain
hope its nothing important... i barely do 130+ anyways, i usually shut off after 100 unless i'm going berserk
