Relocation brackets on a non lowered car ?
Old Nov 21, 2003 | 05:13 PM
Prorac1's Avatar
Whats the general consensus. Does it do any good. Thanks Prorac1
Old Nov 21, 2003 | 05:33 PM
Red_94Formula's Avatar
yup it still helps traction wise. any effort to lower to lower the arms helps push the car upward better
Old Nov 21, 2003 | 05:37 PM
Buttercup's Avatar
Depends on what you want out of your suspension. For drag racing, the relocation brackets allow you to change the suspension geometry for better antisquat.... the lower you drop the axle side of the LCA the more it loads the tires, resulting in better 60' times. Of course, nothing is free, too much LCA angle can induce wheel hop on braking and may give the car a "loose" feeling.
If it's just for drag racing they are an inexpensive mod that can help and you can level out the LCA's for regular driving, autocross, and road racing. Of course if you ever plan on autocrossing or the like I do think LCA brackets change the car's class.
Old Nov 21, 2003 | 05:55 PM
D James's Avatar
sphon claims up to one tenth better on your 60ft with them
Old Nov 21, 2003 | 08:28 PM
Prorac1's Avatar
Thank you for the responses. Sorry, i forgot to add that in there, it is a drag / street suspension with a pention towards drag. So i would want to lower the axle side of the control arm. Where do the brackets go (rear end or body). Thanks again, prorac1
Old Nov 21, 2003 | 08:32 PM
S.J.S.'s Avatar
rear end side.
thenewkid
Nov 27, 2014 09:41 AM
lbrowne
Nov 13, 2011 04:25 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
