Clutch
Old Nov 21, 2003 | 07:38 AM
93ZM6Tally's Avatar
Clutch
I have a new SPEC stage 2 ready to go in. I was planning on resurfacing the flywheel but have seen posts suggesting that you shouldn't re-surface the flywheel with a SPEC clutch. If I do re-surface or replace the flywheel how do I balance it, neutral or do I have the machine shop make it match the existing flywheel balance.
Old Nov 21, 2003 | 08:11 AM
IslandZ's Avatar
You should be fine with a .005 resurface. IF it hadn't been resurfaced before!
On the side though, you run 12's and you went with stage 2????
Why?
Old Nov 21, 2003 | 08:54 AM
93ZM6Tally's Avatar
Not enough? I bought that clutch a good while back, but supposed good to 450Hp. The times in my sig are with a stock clutch that has 80k on it.
Old Nov 21, 2003 | 09:16 AM
IrocManiac's Avatar
I think you'll be fine with a stage 2...I wouldn't consider anything less than a stage 2 with spec I've heard too many horror stories. Stage 2 should be just what you're needing...heck the SLP setup probably would been just fine for your car as it sits right now.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
