Rocker install tech. question
Just got all new (Comp Pro Mag 1.6's) rockers and LT4 valvesprings installed last night. That's it for now. Here's the way I did the install:
#1 piston at TDC (compression stroke), arrow on balancer at 12 o'clock, removed old valvetrain, installed new stuff, cranked nuts down on intake and exhaust valves 180 degrees (1/2 turn) from "0" lash, tightened down allen heads inside rocker nuts. Turn crank 90 degrees (3 o'clock position), #8 cylinder, etc.... 1-8-4-3-6-5-7-2 Oh yeah, and PLENTY of moly grease n' oil used on everything.
Am I OK so far? Just want to make sure before I crank it over since this is my first time messing with V8 valvetrain.
Now for the valve covers. What is the best way to remove the support frames inside them? I'm not sure if I can get my Dremel all the way in there. Do I leave the long shims in there that the bolts go through? Anyone got some good pics of the finished product?
Originally posted by Compstall
I checked your site earlier today. Yep, looks like I used Method #2.
So how 'bout them valve cover support frames?
My buddy cut his all the way off, tube, arms, and all, and had leaks.. I have no leaks to this day
Re: Rocker install tech. question
Originally posted by 96 WS6
I just straightened that part with some vice grips... goes on fine and doesn't rub.
Thanks for the help guys. I hope it works out. I test fitted the valve cover last night and it fits fine now. I'll be finishing up the job tonight. All that's left is the valve covers, AIR fittings, alternator, and serpentine.
oldschool
Feb 9, 2016 09:21 PM
