Less then 3/8 tank = hard start???
Old Nov 23, 2003 | 11:00 PM
Xride's Avatar
I thought I had the hard start fixed with I replaced what looked like the stock 96 battery with a Red top. but I have found that once my fuel level gets below 3/8 it hard starts.
I'm afriad this means feul pump, but want to make sure befor I undertake something that big.
Also why only under that much fuel? not enough power to pull the feul from that low???
Old Nov 23, 2003 | 11:07 PM
longwaytofall's Avatar
hard start as in you are cranking for awhile? i know on my diesel truck when i get a low tank it does that too. i have a small air/fuel leak in some of the injector lines, so when i shut the car off it pulls air into the fuel filter, making it start and die. but when i have full tanks and on a slight downhill angle, the pressure in the line is positive, so no air sucks in. u can try looking for leaks or seeing if parking at an angle helps at all.
Old Nov 23, 2003 | 11:16 PM
96z's Avatar
96z
The gas gauges on these cars are notoriously off. Trying priming the fuel pump by turning the key to the on postion to see if that helps.
Old Nov 23, 2003 | 11:35 PM
Xride's Avatar
yes it cranks exceisivly, I let it prime for the 5 seconds or whatever it is that I can hear it.
I know the guage can be off, but I have been know to run it right to if not past the line without running out of fuel in dire time waiting for my pay check.
Old Nov 24, 2003 | 12:03 AM
JKDZ28's Avatar
lol your probably out of fuel, because i get nervous when the gas hand gets to the left of full
Old Nov 24, 2003 | 12:20 AM
Xride's Avatar
but it will start, and i'll drive another 100 km befor i fuel up most of hte time, depends if I have cash or not.
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
