Fuel Injector ticking.
Old Nov 23, 2003 | 11:41 AM
Heatmaker's Avatar
Advanced Member
I have a loud and annoying ticking sound comming from my driverside Injector/Valve cover area. when you stop on the car I'm almost certain the ticking gets louder. Bottom line it shouldn't be there. Is there a cool way to check and see if it's the Injector or the Lifter? Does anyone know of a good Compressed Fuel enjector Cleaner..the professional type..or should I replace the injectors? Just curious because the previous owner took really crappy care of my car and she idled and ran like sh8t. I've tuned the hell out her and she's running strong..but some things I have yet to look at...like the injectors.
Old Nov 23, 2003 | 11:47 AM
IrocManiac's Avatar
It may be a leak off the right side manifold...they make a ticking noise when that happens...a pretty loud one too...I wouldn't start replacing things like injectors till I knew for sure what it was...
Old Nov 23, 2003 | 12:45 PM
Cmr0z28's Avatar
I have the same thing. I thought it was the lifters, but I got a stethascope and pinpointed where the noise was coming from. It's just the injectors making a ticking noise while opening and closing.....pretty normal on LT1's.
Old Nov 23, 2003 | 02:36 PM
Heatmaker's Avatar
Advanced Member
The funnything is the Ticking seemed to get louder after I install the headers. I'm blown gaskets and had exhaust leaks before but there's no carbon build up or popping around the exahust ports. It's right in between the Injectors and Rocker area. IF one of the injectors is acting up sould I try cleaning it first? THink that might help?
Old Dec 3, 2003 | 05:55 PM
kgkern01's Avatar
So if my intake manifold is leaking, that would create a ticking noise?
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
