best Roller rockers?
Originally posted by BBoyce
I like Comp Cams Pro Magnums 1.6:1 ratio with 7/16" studs and flat guide plates.
You will have to clearance the support ribs inside the valve covers a bit, but it's not too bad.
CC 1.6RR - 1305-16
GM guideplates - 14011051
ARP studs - 134-7103
CMS springs - 611
Best stud rocker... eh, anything not aluminum, whether that's a Pro-Mag, High Tech Stainless, or something like Crower's SS rockers. On mild stuff it isnt as big a deal though
'84, nothin' special required - just unbolt & bolt on
Originally posted by b84camLT1
These require modifying your heads to accept guide plates and the larger studs though right?
Ben
Ben
