How long does the Water Pumplast?
Old Nov 21, 2003 | 12:21 AM
Heatmaker's Avatar
Advanced Member
My car has 53K miles on her...How long exactly does the stock water pump last?
Time for preventive upgrade?
Old Nov 21, 2003 | 12:24 AM
94zLT1's Avatar
wait till you see your gauge start to rise. myswell keep it if it been going strong this long
S.J.S.'s Avatar
You score....mine only lasted 43k.
Old Nov 21, 2003 | 12:36 AM
Heatmaker's Avatar
Advanced Member
my temp gauge is rising
Old Nov 21, 2003 | 01:14 AM
Blu85ROC's Avatar
It'll last about as long as your Optispark . Seriously though... it'll take the Opti with it if you wait untill it goes out.
Old Nov 21, 2003 | 01:29 AM
Heatmaker's Avatar
Advanced Member
Should I change it?
CSI or Meizerre?
Old Nov 21, 2003 | 01:34 AM
Blu85ROC's Avatar
Mine lasted 100k miles, I was surprised. I wasn't paying attention and it started to leak and destroyed my Opti. Just make sure if it starts to leak to change it ASAP or you'll be FUBAR. It's alot cheaper to get just the H2O pump for 150 then the pump and another 400 for the Opti.
Old Nov 21, 2003 | 07:46 AM
Mine was done at about 40k, but even though it leaked, it never caused the engine to run any hotter. I would bet your problem lies elsewhere.
If your pump is not leaking out the weep hole, it's probably ok for now.
Old Nov 21, 2003 | 08:00 AM
mint97z28's Avatar
Mine was replaced at 87k.
Old Nov 21, 2003 | 08:02 AM
Patman's Avatar
Mine died earlier this year, somewhere around 80-85k.
Old Nov 21, 2003 | 08:04 AM
RE AND CHERYL's Avatar
Cool
Mine went till 107K. Go figure.... My original opti got dreanched when it went but after a good cleaning, it lived.
P.S. I got a reman water pump from Auto Zone for $40.
Old Nov 21, 2003 | 08:12 AM
BitCypher's Avatar
While installing Jet-Hot LTs on my car last weekend I noticed that the water pump weep hole shows signs of drainage. The car has 94k miles and running the original pump. The weep hole isn't wet or dripping at the moment so my guess is that it is leaking when the engine is running and stops leaking when the engine is off. I'm changing it tomorrow while finishing up my LT install...just to save my Opti (which is original too).
Old Nov 21, 2003 | 08:40 AM
ead94z28's Avatar
118,000 mi. and still going
Old Nov 21, 2003 | 09:05 AM
quicksilver97ta's Avatar
My original pump went at around 20K, still under warrantee. I just finished removing the second one at 60K due to a new opti and CSI install.
Old Nov 21, 2003 | 10:05 AM
DR.ZED's Avatar
I have 180,000 MILES on mine. Stock since new.
Think I'm tempting fate??? I think so.
Time for a replacement this winter I think.
