opti-spark problem
Old Nov 21, 2003 | 07:14 PM
NJCustoms's Avatar
opti-spark problem
Ok Guys IA just want someone elses option on this. My car is hard to start, It cranks fine, but when it fires, it stumbles really bad for a few seconds then the rpm hols steady @ 2 Grand. When driving i have to keep a LIGHT foot, anything more then 1/2 throttle it will back fire and pop BAD along with lost of power. I have a set of new MSD wires and a set of Rapid fires I am going to put in tommorw. Should I change the opti-spark too? From what I read in my search that is a CLASSIC TELL TALE SIGN. Am I correct in thinking? Thank Once again, John
Old Nov 21, 2003 | 08:25 PM
drewstealth's Avatar
Yeah it sounds like your opti. But before you replace it i would do the wires and plugs first. Also i would check you coil out. If all is good then more and likely its your opticrap.
Old Nov 21, 2003 | 08:51 PM
jakesnake123957's Avatar
scan it and see what codes are there if any,Jake
Old Nov 22, 2003 | 01:02 AM
Antz97ZNJ's Avatar
Opti, number one lt1 problem since the beginning
Old Nov 23, 2003 | 03:14 PM
NJCustoms's Avatar
Talking
I was wrenching all week end. Plug 2 ,7, and 8 were ORIGINAL!!!! the wires were too!!!! I changd the Blugs ( Bosch Non Palt.) MSD 8.5 wires. Coil ( MSD), Ing. Moudle, Dist and Opti spack.. IT RUNS LIKE A RAPED APE.... WOW.. Thanks Guys
Old Nov 23, 2003 | 03:17 PM
NewbieWar's Avatar
heh i know what u mean i just pulled Bosch supers outa mine, and put all new wires on and damit, it runs like the worlds coming to an end
Old Nov 23, 2003 | 05:49 PM
Talking
Glad you fixed it! Sure feels fine to have some horsepower!,>Jake
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
