Pulling crank hub (link)
Old Nov 22, 2003 | 07:39 AM
slmdgmc's Avatar
Just wondering if this type pulley would work well for pulling the crank hub off.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444408847
Then I was going to make a installer out of allthread and washers. Does this sound like a good plan?
Old Nov 22, 2003 | 08:04 AM
LPE Z convt's Avatar
Sure you could use that but autozone sells the one you need for like $15......
Old Nov 22, 2003 | 08:30 AM
NOMAD's Avatar
You really need to use a 3 bolt puller. The jaw ones really put a huge strain on the balancer on an lt-1. They are very very tight on there usually. It's much easier to pull the entire assembley off due to the cramped spaces and the fact a jaw puller is quite a bit awkward to use.
-Shannon
Old Nov 22, 2003 | 08:34 AM
slmdgmc's Avatar
So I need to get one that looks like a bird's foot and bolt it into the three holes that hold the balancer to the hub. Then put something inside the crank threads (1/4" drive extension?) that can be pushed against by the middle bolt to push the hub off, correct? The threads were messed up when I first got the engine so I re-tapped it to 1/2" (too bad to just clean) so I really only have one chance to do this right before I need a new crank.
Old Nov 22, 2003 | 09:28 AM
jakesnake123957's Avatar
Buy a manual at auto zone and follow it to the letter,hope this helps you.Jake
You need to also take out the middle bolt and get a smaller bolt to push against the crank... The best way to pull the pulley would be to use the puller that looks like a bird's foot with londer (grade 8) bolts thread them through the pulley and put a nut on the back side of each of the 3 bolts... Then that will take the stress off the threads because if your pulley is like mine you will think it will never come off but it will.......
cyteone
Feb 7, 2015 06:04 PM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
