water problem need help
Old Nov 21, 2003 | 02:06 PM
red_warrior_z28's Avatar
i have recently found water on the passengers side floor. only happens when the a/c is turned on. i have heard that if something from the a/c clogs up it will do this. if any of you know what it might be and how i could fix it let me know
any help will be deeply appreciated.
thank you
Old Nov 30, 2003 | 09:55 AM
slopokrodrigez's Avatar
If it only does it when the A/C is on, that would indicate the drain is clogged where the water usually drips out on to the ground. Check 2 things, 1, see if the dripping does not occur under the car like it should when the A/C is on. Also, check the rug on the passenger side to be sure it doesn't have any anti-freeze on it. Chances are it doesn't have anti-freeze on the rug and the hole is plugged. It would be best to unclog from the inside but if that is too difficult, a well placed blast of compressed air from outside the car under the firewall would work well.
Magenta_Hearts
Mar 29, 2017 08:54 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
