will 5x120.65mm lug bolt patt. fit on 94 z?
Old Nov 22, 2003 | 05:45 PM
glennxx1's Avatar
no clue what reg. bolt pattern is, thanks
Old Nov 22, 2003 | 08:56 PM
LWillmann's Avatar
4th gen's official bolt pattern is 5x4.75 I believe. That would make the bolt circle around 120mm, so I think they'll fit.
Old Nov 22, 2003 | 09:06 PM
OldSStroker's Avatar
120.65 mm / 25.4 mm/inch = 4.75 inches. That's correct for Z and many other Chevys for about 40+ years.
Make sure the center hole is not undersize. The hubs are 2.768 inches I believe for 93 >Camaro. If wheel bore is larger consider using adapter rings to make the wheel "hubcentric".
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
Moshbmx1
Jan 20, 2015 03:27 PM
