Jet Hot LT question
Old Nov 23, 2003 | 11:00 PM
Red96Lt1's Avatar
Jet Hot LT question
I just got my jet hot LT's in and I had a question about the #1 primary. How do you get it in the rest of the headder. And when you install it, do you have to weld it or is it just a friction fit? I've thought about putting it in the freezer to shrink the tube down. Any suggestions? Thanks!
Old Nov 23, 2003 | 11:02 PM
CamaroBoy96Z28's Avatar
I sanded the bottom of the slip in primary slightly by hand so it would slip into the tube. No leaks. Just slide the primary in and go.
Old Nov 23, 2003 | 11:07 PM
speed76demon's Avatar
Well I had no trouble with leaks for 5 months now that its colder out its starting to leak
Old Nov 23, 2003 | 11:13 PM
Red96Lt1's Avatar
Did you sand yours too? And how cold?
Old Nov 24, 2003 | 09:58 PM
revtime's Avatar
I simply put a towel over the tube then I got out my BFH and pounded it in.
Good thing I have alot of sexual frustration.
Old Nov 24, 2003 | 10:01 PM
Sweetred95ta's Avatar
Man, I dont think I would be admitted that kind of stuff ^. I'll have to call you up to help me if my headers need "worked" if sexual frustration is what it takes.
Benji
Old Nov 25, 2003 | 11:30 AM
Red96Lt1's Avatar
LOL!!
Old Nov 25, 2003 | 11:41 AM
madwolf's Avatar
Mine went it without any sexual frustration. [Butt-Head]He said: Went in....[/Butt-Head]
I just sanded it very lightly with some fine sand paper and then hammered it in with a rubber mallett.
Old Nov 25, 2003 | 11:56 AM
thebrainhart's Avatar
Mine went in without any problems or modifying, and as far as I know, don't leak still, several months later.
Old Nov 25, 2003 | 12:51 PM
RallyRed701/2's Avatar
ditto...
Old Nov 25, 2003 | 01:26 PM
doodad's Avatar
My coating was pretty thick on mine. Sanded down and it fit fine, but does leak a little. I need a 3/4 inch clamp to seal that puppy.
Old Nov 25, 2003 | 02:40 PM
ibanez6rg's Avatar
Mine went in with an uncontolable force that I call MUSCLE!
BTW, I don't think you need to put a freezer. Doubt it would have any effect at all.
Old Nov 25, 2003 | 04:23 PM
Red96Lt1's Avatar
I guess I need to get me one of those MUSCLE things. Can you get them at Autozone?
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
RedLineRev
Jan 23, 2003 03:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
