H20 Pump Wiring?
Old Nov 22, 2003 | 06:26 PM
1FastRedZ's Avatar
H20 Pump Wiring?
I'm wiring my H20 pump and was wondering where to tap into for power. I don't want to use power from the fuel pump. I want the pump to run when the key is in the on position only. I also don't want the engine to be on for the pump to work.
Old Nov 22, 2003 | 06:32 PM
S.J.S.'s Avatar
send it through your firewall if you want like a gauge. I hooked my wire up to a male connector and just plugged it into the plug next to the ignition fuse in the fuse box. How much amps does it require? I can send you a pic if you like.
Old Nov 23, 2003 | 08:30 AM
1FastRedZ's Avatar
It doesn't pull much power. I just want to be able to prime the system w/o the car on.
Old Nov 23, 2003 | 08:49 AM
96speed's Avatar
You need to use a relay. I used my ignition circuit as my switched source.
Ryan
Scottyboy
Feb 11, 2015 10:28 PM
BMX Dad
Jan 23, 2015 07:00 PM
lbrowne
Nov 13, 2011 04:25 PM
