Lt1 Scan master wiring?
Old Nov 21, 2003 | 05:04 PM
ChevyIron's Avatar
I just picked one up,I know it comes with no harness to plug in you have wire it in yourself.I know it needs 12 volts swithched and ground but am not sure were the data wire gets hooked up to the ALDL connector?How do I postively Idetify that I am hooking up to the right wire.The car is a 97 Z with OBD1 computer on board.Thanx in advance.
David
Old Nov 21, 2003 | 05:24 PM
Red95Formula's Avatar
You are correct you need 12 volt pwr, gnd, and then the 3rd wire hooks up to the tan wire on the ALDL, i am not sure what pin # it is though.
Old Nov 22, 2003 | 02:09 PM
arnie's Avatar
Fred, (Injuneer) has a scanmaster 'how to' if interested. It includes the wire install info.
Ah, here it is: http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Nov 22, 2003 | 02:56 PM
Brent94Z's Avatar
Super Moderator
For a 97 the wiring will be the same as on this page...
http://www.bfranker.badz28.com/fbody/scanmaster.htm
Old Nov 22, 2003 | 03:59 PM
ChevyIron's Avatar
Thanx Brent for the link,very helpful
DirtyDaveW
Dec 1, 2016 05:37 PM
Injuneer
Dec 15, 2014 09:36 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
