My Heater gives off a FOUL odor sometimes?!?
Old Nov 23, 2003 | 10:52 PM
96redformula7's Avatar
My heater after it has warmed up and the air is really hot starts to give off this really stange burning odor sometimes. I notices it always happens at certain streets and then sometimes it just gives off the smell at random times. Any help would be apreciated and I bow down to you.
Old Nov 23, 2003 | 11:00 PM
VegasZ's Avatar
You may be having the same problem I had. The heater inlet, which is actualy right under the cowl of the hood, was sucking in fumes from under the hood. The fumes from under the hood had a burning smell because my EGR valve was leaking. Once I replaced the EGR valve, the smell was gone. I had a code for the EGR valve at the time as well. Something to check.
Old Nov 23, 2003 | 11:50 PM
No codes being thrown.
Old Nov 24, 2003 | 01:17 AM
InjectedSS's Avatar
does it smell like coolant?
Old Nov 24, 2003 | 01:22 AM
I am really sure it doesn't smell like coolant.
Old Nov 24, 2003 | 01:23 AM
S.J.S.'s Avatar
does it smell moldy?? If so....your heater core might be leaking water into the duct and the water just gets stagnent. Just a thought.
Old Nov 24, 2003 | 10:23 AM
Fatdog's Avatar
Cool
With the engine running,and the heater blower on,might spray a 1/4 can of Lysol into the vents(behind the hood by the windshield wipers).This will kill any mold if thats the problem.Open the windows though because Lysol really stinks itself.My02
Old Nov 24, 2003 | 11:33 AM
BUBBA's Avatar
Make sure your AC drain pipe is not clogged up.
Old Nov 24, 2003 | 11:50 AM
Where is the ac drain pipe? I am going to check the ac drain pipe and do the lysol thing.
Old Nov 24, 2003 | 12:02 PM
BUBBA's Avatar
Go to Shoe's tech. site. See AC drain hole.
Don't know if this is your problem, but if mildew gets in the system because of plugged AC drain, it really can smell like something rotten.JMHO.
And use the lysol before you buy the "special" stuff which costs mucho $$. JMHO
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
RX Speed Works
Sep 11, 2015 03:31 PM
Pwilson59
Sep 3, 2015 08:47 PM
RX Speed Works
Jul 24, 2015 02:25 PM
