Heater Core, Im cold :(
Old Nov 23, 2003 | 03:09 PM
NewbieWar's Avatar
well accually i dont get cold too often but my heater doesnt work, and last night i was shivering driving home. i felt kinda rediculous so i shivered harder to make the people next to me think i was having convultions . but anywho my friend says the two pipes connected to my firewall on the outside are probably supposed to be connected to my heater core, and thats why my heater doesnt work... so what do i have to do?
its really hard to pick up chicks if they get cold in the nice ride
Old Nov 23, 2003 | 03:17 PM
tend2609's Avatar
yeah, those two pipes coming through the firewall are for the heater core.
Old Nov 23, 2003 | 03:18 PM
NewbieWar's Avatar
sooo, what do i gotta do to get my heater workin?
Old Nov 23, 2003 | 03:42 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I had a clogged heater core on my 94Z. I disconnected the hose from the top of the water pump, poured cooling system flush in it, and then took a blow gun and blew compressed air through it.
Worked good after that.
Old Nov 23, 2003 | 04:10 PM
NewbieWar's Avatar
yea thats all good and stuff but mine isnt hooked up
just 2 connection ports on the back of my engine bay.
Old Nov 23, 2003 | 06:43 PM
$hawn's Avatar
Sounds like sombodys by-passed the heater core, or else coolant would be leaking everywhere, there should be two hoses connected together, try hooking them back on the heater core pipes.
Old Nov 23, 2003 | 07:16 PM
BlackLT1_TX's Avatar
hey, i will be willing to bet that the guy bypassed the heater core because he blew the heater core (ex-ghetto rigger myself). when you hook it up, you will find alot of coolant in the pass. floor board.
So, if this happens, you will need to replace the heater core, which i have heard it is a bitch from alot of people and others say it isnt bad in comparison to a mustang fox (i have done those, they are a BITCH)
-james
Old Nov 23, 2003 | 07:26 PM
$hawn's Avatar
Blacklt1-tx, I'm glad you mentioned that, about the heater core being by-passed, cuase it would have to be by-passed for a reason(heater core leaking) more than likely. I'm sure there some info or even guides on how to get to/change it.
Old Nov 23, 2003 | 07:29 PM
AsianSensation's Avatar
The supply and return hoses from the heater core goes to the coolant ports on the left hand side of the water pump housing. See pic.
http://www.97ta.com/useless_folder/heatercore1.jpg
Old Nov 23, 2003 | 08:17 PM
S.J.S.'s Avatar
Go buy a heater core ($50) and replace it. It's under the glove compartment. The hoses will be on the passenger side of the engine bay behind the whell weld. They are 2 pipes, you should see them. Don't get them confused with the AC lines. Just took mine out yesterday. Takes like 30 minutes.
Old Nov 23, 2003 | 08:30 PM
Zack's Avatar
cold is having to drive in 50* weather with no ttops on
Old Nov 23, 2003 | 08:41 PM
NewbieWar's Avatar
yea my friend was driving around the other day w/ the windows down Brrr
football4life
Oct 4, 2015 07:48 AM
greenzee28
Sep 25, 2015 04:29 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
