whats a f1 camaro?
Old Nov 24, 2003 | 09:18 AM
glennxx1's Avatar
whats a f1 camaro?
and do the 1le sway bars come on certain cars? if so how can you check to see if you have them
Old Nov 24, 2003 | 09:46 AM
OBE1 95Z28's Avatar
The F1 Camaro is a Z28 with ground effects, rear spoiler (add-on piece), stripes, 1LE LCAs and panhard bar and a cat back exhaust system.
Old Nov 24, 2003 | 11:00 AM
From the "4th Gen FAQ":
Q: What's included in the F1-Camaro/Firebird-GT package?
A: This is a package available through most dealerships. It offers a variety of performance and cosmetic parts from the GM Performance Group. The following is a list of the parts for the F1-Camaro (and for the Firebird-GT) and can be ordered for your Z28 or Formula through your dealership:
Part No. Description
12363906 32mm front stab. bar, bushings, link kit, and track bar
12364002 17"x9"x50mm ZR-1 style wheels with P275/40ZR-17 Comp T/A tires
12363998 16"x8"x66mm ZR-1 style wheels with P245/50ZR-16 Comp T/A tires
12363902 6-speed Hurst shifter (leather wrapped shift ****)
12363925 cat-back performance exhaust (dual single-side outlet)
12363940 3 piece rear spoiler (primed)
12363915 4 piece ground effects package (primed)
12363978 cold air induction packge (1993, for use with MAP)
12363979 cold air induction packge (1994 and up, for use with MAF)
12363910 F1 Specialty Vehicle Package - everything above (1993)
12363911 F1 Specialty Vehicle Package - everything above (1994 and up)
123638xx coup floor mats (xx is 94-graphite, 95-gray, 96-beige, 97-neutral)
123638xx conv floor mats (xx is 98-graphite, 99-gray, 00-beige, 01-neutral)
Old Nov 24, 2003 | 11:40 AM
doodad's Avatar
Mine is an F-1. It was prior to the SS return and was advertised as a "build your own supercar." You could go down the laundry list and pick and choose what parts you wanted, which were dealer installed and warranted.
Old Nov 24, 2003 | 11:58 AM
James 97Z's Avatar
http://home.lagrange.edu/james/f1/flier1.jpg
http://home.lagrange.edu/james/f1/flier2.jpg
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
