real bad miss fire after cam swap? please help
Old Nov 23, 2003 | 09:11 PM
ram air camaro's Avatar
Unhappy real bad miss fire after cam swap? please help
i put in a new cam and now i have a real bad missfire i know for sure my coil is good wires are about 6 monhs old and i got pcm tuning and turns out it gets worse with tunning??? any suggestions or solutions please oh forgot to mention all my spark plug wires are glowing at night, i could see all the current going through them like looking at lightning all the wires are doing it i have taylor wires if that helps?
Old Nov 23, 2003 | 10:23 PM
Check plug wire routing. You are not supposed to be able to see glowing along the wire on a good set of wires.
Old Nov 27, 2003 | 01:30 PM
TenaciousZ's Avatar
Re: real bad miss fire after cam swap? please help
I have the same problem, except the glowing wires, I put in the new tuned pcm and it will misfire on me.
Old Nov 29, 2003 | 09:20 PM
it has'nt miss high rpm in two days now since i readjusted the rocker arms but still got the low rpm miss and glowing wires. i lost to a 2003 mustang mach 1 today which i was really dissapointed.
Old Nov 29, 2003 | 10:42 PM
JoeliusZ28's Avatar
I just just gonna reply to your thread in the lounge: "Is this why?"
Old Nov 29, 2003 | 10:57 PM
Heatmaker's Avatar
Advanced Member
A couple of questions
1. Did you add the Taylors at the same time you did the Cam swap?
2. Did you check the Timing Sequence?
3. Can you please take a picture of you glowing plugs sounds kind of cool
chuyz28
Feb 19, 2015 12:50 AM
Amshnock
14
Jan 18, 2015 11:47 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
Dave19yz28
Jan 26, 2003 01:45 PM
