correct/good fuel PSI
Old Nov 22, 2003 | 04:48 PM
z28marine's Avatar
i just checked the fuel pressure and it would at first jump to 42 psi as the pump primed, then drop to 39psi. Is this a sign that the fuel pump is good or bad?
Old Nov 22, 2003 | 05:17 PM
Van5150's Avatar
1st off Marine, your having one problem, make 1 thread, this way we can see your progress. In my experience fuel pump was all or nothing, when was the last time you changed your fuel filter ?
Old Nov 22, 2003 | 05:32 PM
z28marine's Avatar
i changed the filter about 6-8 thousand miles ago
Old Nov 22, 2003 | 06:34 PM
$hawn's Avatar
Those are my fuel pressure numbers, as long as it stays at 39psi for awhile, it's fine.
Old Nov 23, 2003 | 05:45 AM
slopokrodrigez's Avatar
What is the fuel pressure after the engine is shut down for a while?
Old Nov 23, 2003 | 05:58 AM
badass383's Avatar
I happened to notice you posted another question about the car cutting out after it was low on fuel. If you would have kept the original post going, it would have been easier for people to answer you.
For example you said the car cuts off intermittantly in your first post. In this post you said the fuel pressure is 39psi. Well for the outsider looking in it seems as though you checked the pressure when the car is running fine. Did you check the pressure when the engine quits on you?
The only way you can do this is tape a pressure gage to the windshield (one with a hose obviously) and drive it until you have a problem.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Alex Barnes
Jan 24, 2015 10:21 PM
