Hot Cam spring pressure
Old Nov 21, 2003 | 08:32 AM
Z-RATED94's Avatar
Anybody happen to know what the open and closed spring pressure is for the Hot Cam springs?
Thanks, Rick
Old Nov 21, 2003 | 01:14 PM
NightTrain66's Avatar
I believe they are 105 lbs at the seat and 280 open. The Hot cam springs barely work for the Hot Cam and they are VERY close to coil bind. I would rather have more seat pressure but there is no room since coil bind is so close anyway.
I would recommend the Combination Motorsport (702-798-8504) 612 springs. they are $80 for spring, retainers and locks. They require no machining and will have about 130 on the seat and about 330 open. they can handle quite a bit more lift as well (.570 to .580 depending on set up ht.).
NightTrain66
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
